Hey everyone, I wanted to share my experience integrating older ESP32 devices with Home Assistant using MQTT. I’ve been working on this for a while and thought it might help others facing similar challenges.
First, I encountered some authentication issues when my ESP32 tried connecting to HA’s MQTT broker. The logs showed errors about null usernames or passwords. After some research, I realized that disabling authentication temporarily could help troubleshoot. Once everything was working, I re-enabled security measures, ensuring my setup was secure.
Here are a few tips I’ve gathered:
- Start Simple: Begin with a basic setup without authentication to confirm connectivity.
- Check Logs: HA’s logs are invaluable for diagnosing connection issues.
- Update Firmware: Ensure your ESP32 firmware is up-to-date to avoid compatibility problems.
- Security First: Once everything works, secure your MQTT broker with strong credentials or tokens.
It’s been a rewarding process seeing my older devices work seamlessly with HA. If anyone has specific questions or needs advice, feel free to ask! ![]()
