MQTT Signal Issues and Tips for Home Assistant Setup
As a homeowner with a multi-family residence, I’ve encountered some challenges with my MQTT signal reaching the basement. Despite having only two available outlets, I’ve managed to set up my ESP8266 devices using the Homie framework. However, I noticed that after a recent Home Assistant update, the online states of my devices weren’t being picked up anymore. Clearing the topics and resetting the devices helped temporarily, but the issue persisted. I’m curious if others have faced similar issues and if there’s a workaround without having to restart the entire system frequently.
On a lighter note, I wanted to share a tip I discovered while configuring my Home Assistant setup. I’ve been using the Cert Expiry sensor and MQTT integration for monitoring my devices, but I stumbled upon an issue with the MQTT configuration after the update. After some research, I found that adjusting the value_template in my MQTT sensors resolved the problem. It’s been a steep learning curve, but it’s rewarding to see everything working smoothly now.
Another thing I’ve been exploring is setting up a default dashboard on my Home Assistant instance. I’ve created a main dashboard with quick access to the most frequently used features, and it’s been a game-changer for my daily routine. It would be fantastic if there were an option to set this as the default view without navigating through the dashboard index every time.
If anyone has tips on optimizing MQTT signal strength or has encountered similar issues with Home Assistant updates, I’d love to hear your experiences! Happy tinkering everyone! :blush:
