What solutions have you come up with to control an IR Mr.Cool Mini Split ? I want to add a more traditional thermostat experience instead of the remote which has no programming or automation options.
@zbrpsfnwpk Great question! For adding a smarter, more traditional thermostat experience to your IR-controlled Mr.Cool Mini Split, the Aqara Climate Sensor W100 paired with an Aqara Hub M3 is a solid path to explore. This combo lets you wirelessly control your mini split via IR—adjusting temperature, mode, and other settings remotely—without ever touching the original remote. Plus, you get automation and scheduling through the Aqara Home app, which beats manual remote control any day.
If direct IR compatibility with your specific Mr.Cool model is tricky (since IR compatibility isn’t 100% guaranteed across all devices), you can also leverage the customize remote control feature available on Aqara hubs like the M2 or M3. This lets you build custom IR commands tailored to your mini split, improving the odds of getting reliable control.
For a full thermostat replacement with automation conditions, keep in mind that Aqara’s dedicated thermostats like the Thermostat S3 are designed for water-system HVAC (central air, floor heating, fresh air) and don’t support IR or “fluorine machine” air conditioners like mini splits. So the W100 + Hub M3 IR route is your best bet for your setup.
Have you tried any IR blaster solutions already, or are you starting fresh with Aqara gear?
Hi there.well as @AqaraBot mentioned you can add your AC on M3 hub and add the Aqara w100 climate sensor as the thermostat.i have my AC set like that and I can automate it to turn ON/Off on the hours I want and also you can set to turn On or Off base on the temp with the w100 provide.mine works perfectly fine.
@coccolino_26 Hey @coccolino_26, thanks for sharing your setup! It’s always great to see real-world success stories from the community. Your Mr. Cool mini split integration sounds like a solid solution for anyone looking to add programming and automation to an IR AC.
Just to build on your post for anyone else reading: the Aqara Hub M3 has a built-in 360° IR blaster that can expose connected IR AC units to Matter, and it can act as an AC thermostat when paired with an Aqara Climate Sensor W100. This means you can automate based on temperature, set schedules, or even use the W100’s buttons to trigger scenes.
One quick tip: make sure your M3 is set up with the latest firmware so the IR learning and Matter integration work smoothly. Also, placing the W100 away from direct sunlight or heat sources will keep your temperature readings accurate.
Thanks again for the tip—it’s helpful for all of us exploring smart thermostat alternatives! If anyone else has tried this with different IR AC brands, feel free to jump in and share.
This information comes from community discussions and user experience summaries and may vary by environment. Please verify carefully.
If you have IR on board - then you can use an IR Blaster. G3,G350,m3 and M200 should work there
