My camera is making static noise every 4-5 second when streamed via amazon echo show? Any fix ? G100 camera
How to fix this static noise? I have 8 g100 at my home and its the same issue through each.
Hello, friend
This is an issue caused by the update of the new firmware for the echo show. We are currently updating the camera’s firmware to solve this problem and it is still under testing.you need wait for a while.
Can you please give me time frame. As i have bough over 12 Aqara cameras and i have 3 kids. When they sleep i stream it thru alexa. One there is static noise periodically after every 5 seconds which wakes up the kids moreover the stream on alexa last few minutes. If this is not fixed i will have to change my house eco system unfortunately as I cant leave my kids alone without camera.
Thank you
Does the problem still exist, my friend? Amazon has urgently released a fix patch, and many users have told me that their Aqara cameras no longer have noise. Please provide me with your Aqara Home account so that I can arrange for a colleague to upgrade the new firmware for all your G100 cameras, and then confirm if the problem still exists.
I have upgraded the firmware. Yes this issue is resolved but now there is a new issue when streaming it automatically stops streaming after few mins. ( that never happened with littlelf camera that i was using before this). Can you please look into it as this is a very important reason I bought aqara cameras.
Also another issue i am facing is lagging in the door bell. I have tried restarting the bell and the router. It resolves the issue for a day and then it again starts lagging. Whats the reason and can you please fix this as well? Thanks
Just to confirm all my g100 cam settings say firmware is latest. Do you have another version ( stated above) which is not via the app and only your team can update that?
Thanks
Can you please look into it?
I also have this problem from the beginning with the camera. By seeing it from HomeKit and also from the aqara app. It always has a background noise that is not quite fixed. Any solution?
Please take a video of this issue for me
Here I upload a couple of videos. If you need anything else, ask me. Thank you.
I carefully watched these two videos. In the first video, I didn’t hear any abnormal sound, and in the second video, there was some slight background noise. However, it seems to be within our reasonable evaluation range. This issue seems to be different from the topic discussed in this post. Has it affected your use of the product,friend?
I’ll look for another video again so that what I’m saying is heard better.
