I was very lucky to be selected in the first batch of testers for the new Aqara Outdoor String Lights H1. Having spent the last few weeks testing them in the garden (and running them through my smart-home setup), I wanted to share my honest thoughts on how they perform in real daily use.
For context, our home is an ongoing mix of Aqara, Home Assistant, Apple Home, Zigbee, Thread, and Matter. I have tested quite a few outdoor lights over the years, and finding something that balances solid weather-proof hardware with proper smart integration is usually where things fall apart.
First impressions and build quality
The first thing that stands out when you open the box is the sheer length: 30 metres of lights in a single string.
Anyone who has tried decorating an outdoor space knows the familiar headache of measuring, hanging a strand, and realizing you are three metres short of the corner, which means ordering extension packs and dealing with bulky waterproof connectors in the middle of a wall. Having 30 continuous metres right out of the box makes routing around a patio, pergola, or fence painless.
The physical construction feels properly heavy-duty. The cable is thick, the lamp sockets feel well sealed against wind and rain, and the whole assembly feels like permanent outdoor hardware rather than temporary holiday decor you have to baby when it pours.
The light output itself was a pleasant surprise. Many decorative string lights are essentially faint glowing dots. The H1 lamps are genuinely bright, the individual colours are vibrant and distinct (they do not wash out into dull pastels), and the color blending across the string looks very smooth.
I haven’t gone through a full summer with them yet (which I am already looking forward to for evening gatherings), but with Christmas just around the corner, having this kind of warm, customizable atmosphere in the garden has been fantastic.
Setup and everyday use
Pairing the lights to the Aqara hub took less than two minutes in the Aqara Home app. From there, browsing the built-in effects and tweaking the brightness is completely intuitive.
If you just want to pick a tasteful scene and let it run, the predefined options look polished straight away. But if you like to tinker, creating your own custom palettes and timing is straightforward.
Home Assistant integration (and the one real letdown)
Where these lights get really interesting for me is how they fit into a wider smart home. By pairing them to an Aqara hub, they expose cleanly to Home Assistant (via Matter or Apple Home integration), letting you tie the garden lights into sunset schedules, motion sensors, or night routines.
And that brings me to the one real drawback of the current software: the 15-scene limit in Scene & Signal Sync.
Inside the Aqara Home app, you have around 60 dynamic lighting scenes and effects to choose from, and many of them are genuinely creative. But when you want to expose those scenes to Home Assistant or Matter via Scene & Signal Sync, Aqara caps you at 15 selectable presets.
For anyone running their home through Home Assistant, this is a frustrating bottleneck. You have this fantastic library of 60 scenes sitting in the hardware, but you are forced to curate a small shortlist of 15 to use in your automations. If you want any of the other 45 scenes on a given night, you have to open the proprietary Aqara app and trigger it manually, which defeats the point of having a unified smart home.
This is strictly a software limitation, not a flaw in the lights themselves. I like the built-in scenes so much that I simply want full access to all of them in Home Assistant, and I really hope the Aqara software team considers lifting or removing this cap in an upcoming update.
Final verdict
The Outdoor String Lights H1 have been an absolute pleasure to test. The 30-metre length alone solves a major outdoor lighting annoyance, the build quality inspires long-term confidence, and the brightness and colour fidelity are top-tier.
A sincere compliment to the Aqara team for creating such a well-engineered product. If they can open up Scene & Signal Sync so Home Assistant users can trigger all 60 lighting scenes, this will easily be the gold standard for outdoor smart lighting.
