My Journey with ESPHome and Victron Integration
As a homeowner with an off-grid solar setup, integrating my Victron equipment into Home Assistant has been a game-changer. I recently took on the challenge of connecting my two MPPT chargers and SmartShunt to ESPHome, and it’s been an enlightening experience!
Initially, I was overwhelmed by the YAML configurations. Each device required its own ESP32, which seemed inefficient. But after some research and trial and error, I found a way to consolidate the configurations. The key was understanding how to merge the external components and UART settings without conflicts.
Here’s what I learned:
  • UART Configuration: Each MPPT charger communicates via UART, so assigning unique GPIO pins was crucial. I used GPIO16 and GPIO17 for the first and second chargers, respectively.
  • SmartShunt Integration: The SmartShunt required its own UART setup, but it was simpler since it only needed one GPIO pin (GPIO18 in my case).
  • YAML Best Practices: Breaking down the YAML into sections for each device made the file more manageable. I also utilized substitutions to keep the naming consistent.
After setting everything up, the results were impressive. I now have real-time monitoring of my solar production, battery status, and energy usage. It’s incredibly satisfying to see all the data flow into Home Assistant seamlessly.
If you’re looking to integrate Victron equipment into your setup, I highly recommend exploring ESPHome. The community resources and GitHub projects are invaluable, and with some patience, you can create a robust system that enhances your energy management.
Would love to hear how others have tackled similar integrations or if there are tips to optimize this setup further!
