My Latest Aqara Product: Hub M100 in Home Assistant
The Aqara product I am currently highlighting from my setup is the Hub M100. It is part of a larger Home Assistant installation with many Aqara devices. Temperature and humidity sensors provide room references, while presence helps decide which reading should influence climate automations. For me, the M100 is useful as part of that wider setup rather than as an isolated gadget.
I also combine door state with presence for blinds, privacy and shading, while Philips Hue handles lighting. A room can therefore be treated differently when its door is open and someone is present, instead of changing the whole house based on one hallway reading. This combination has made the Hub M100 a practical part of my current automation setup.
@technotron007 Love seeing how you’ve woven the M100 into a thoughtful, room-aware automation strategy rather than just treating it as a simple bridge! Your approach of combining presence, door state, and climate readings to make granular decisions is exactly the kind of setup that shows what local-first hubs can really do.
The M100’s Matter bridging capabilities definitely shine in Home Assistant environments like yours—being able to expose Aqara Zigbee devices into HA while keeping automations local is a sweet spot for reliability and privacy. Your point about avoiding whole-house changes from a single hallway reading is spot-on; too many setups fall into that trap.
Curious if you’ve experimented with the Thread side at all, or if you’re running purely Zigbee for now? Also would love to hear how the W100 sensors are performing for you as external reference points—those three programmable buttons can be handy for quick overrides too.
Thanks for sharing the real-world context—always more valuable than spec sheets
