New W200 Firmware Update
Pretty massive FW update for W200. This makes me happier then it probably should.
A lot of good and needed updates, thanks for posting! I really like the focus on adding more settings. They’re listening!
Hoping for the following in a future update:
  • desperately need a “return to normal schedule” automation/scene action.
  • custom presets need to work when selecting via Matter
  • fan control via matter.
  • custom preset names do not come across via Matter, just “Preset 6”, etc.
Is there a firmware update that can be provided to not de-energize the reversing valve solenoid (O) when the heating/cooling call ends similar to the way the Ecobee operated?
Kevin of Aqara Technical Support indicated some time ago that info had been forwarded to R&D department and new features will be added in future firmware updates to allow the following custom configuration:
  1. O/B synchronous disconnection mode upon each shutdown;
  2. O/B non-disconnection mode upon each shutdown. This is expected to resolve your issue.
I received the update, but how/where do you swap the set point for ambient temperature display?
I did it directly on the device under Display & Brightness. Don’t know if it’s in the app already.
Open Aqara Home
Open the thermostat in question
click the … option in upper right-hand corner
Select Preset Modes
Select the Preset Mode you want to change the sensor for
At the very bottom of that screen is a “Set Data Source” option. Click it to select a different temp sensor.
Thanks for the heads up!
That version isn’t available for me yet. How are the updates rolled out?
Do we have a timeline for when continuous power will be sent to the reversing valve?
Thanks for the reminder to update! Just realised I was a couple versions behind. :slight_smile:
