Newbie in Home Automation / Smart Home
I’m just about to start my journey into smart home. Been researching around and there’s no clear answer.
For a beginner, I’m planning to get:
  1. Smart Switches for most of the lights
  2. Smart Bulb for bedside lamps
  3. Smart door Lock
  4. Smart Curtain and Blind roller
  5. Sensors
Use cases / Automation
  1. Turn on lights and open curtains when I reach home
  2. Turn off light and close curtains when I leave
  3. Turn off all lights and close curtains when I go to sleep
  4. Dim lights at night
  5. CCTVs
Questions:
  1. Do I need a M3 Hub to execute automation?
  2. If I get a M3 hub, must I get Aqara zigbee products only or I can integrate other brands with zigbee as well.
  3. Can I use China Accesories on Global Hub or Global Accesories on China Hub?
  4. Can I connect my autogate to a smart switch and make my autogate smart? Eg, when I’m reaching home when using Waze, gate will be open when I reach the front entrance
  5. I currently have a Xiaomi Hub 2 that is working on curtain motor, can I integrate that into Aqara Hub?
  6. Do I need a separate device to automate on Home Automation or Apple Home?
  7. How far is the range of M3 Hub? My house is a double storey terrace 22x70, not sure if 1 hub have the range to get full coverage.
Thank you in advance for all the comments!
Greatly appreciate any guides or advice.
Hello, welcome to the forum.
Yes, the Aqara Hub M3 is necessary for most of your scenarios. It acts as the “brain” of the system:
Local work: The main advantage of the M3 is the ability to perform automations locally (“Edge computing”), that is, they will work even without the Internet.
Device support: Your Zigbee switches, sensors and curtains need a hub to communicate with each other and with the application.
Not directly. The Aqara Hub M3 only supports the connection of Zigbee devices from Aqara.
However, you can integrate third-party devices via the Matter protocol. For example, if you have other brand bulbs that support Matter, you can add them to the Aqara Home app via the M3.
If you have a global hub M3, you must use the Aqara Home app with the “Others” region or your country. Chinese sensors purchased on AliExpress usually do not allow you to add to the global hub in the official app.
If you plan to use Apple Home, Aqara regional restrictions do not apply there - the devices will see each other. But for the initial setup in the Aqara app, it is better to buy devices from the same region.
Yes, it is possible. For this you can use a smart relay T2 (T1), which is connected to the contacts on the control board of your gate.
You can set up automation in Apple Home or through shortcuts. There is also the option to do this when your iPhone enters a radius of 100 meters from your home, the gate opens automatically.
This is not possible directly. Xiaomi Smart Home Hub 2 works in the Mi Home ecosystem, and Aqara Hub M3 works in Aqara Home.
You will not be able to add the Xiaomi curtain motor directly to the Aqara hub.
Solution: Combine both hubs in Apple Home. There you can create one “I’m home” button that will simultaneously open the curtains (via Xiaomi) and turn on the lights (via Aqara).
Yes. To control your home via Apple Home when you are away from home, you need a Home Hub.
For a two-story house, one M3 hub may not be enough for stable coverage due to the overlap.
Zigbee Mesh: You don’t have to buy a second hub. Aqara smart switches with a neutral work as Zigbee signal repeaters. If you have smart switches on both floors, they will create a stable network (Mesh) that will “bounce” the signal from the hub to the most distant sensor.
The hub is best placed centrally on the first floor.
___________________________________
MY personal advice: Since you are a beginner, start with the global version of the Aqara Hub M3 and buy official local accessories. This will save you from regional settings issues and ensure Matter support in the future.
Once again, I wish you a pleasant journey in the Aqara smart home!
Thanks for the clarification!
I just researched a bit on Relay and it opened up so many doors to automation.
Just wondering, if it’s possible for any automation for the autogate to open up once I start my car and ready to leave or close when I’m parked?
To do these automation, do I need an Apple HomeKit? Or all these can be done with the M3 Hub? Eg. When I’m 100 meters away from home and the gate opens
If I want to control my home automations or lights when I’m away from home, I can do it through the M3 hub as well?
This is an overview of the T2 relay capabilities. In the topic you can see questions related to opening the gate. Rele T2, let's talk about it again
To get started, you need to research your existing gate opening system and integrate a T2 relay into it. All your opening requirements can be automated.
All this can be done only using M3 and the Aqara APP.
Yes, definitely!!! You can control your smart home from anywhere in the world. The main condition is that the M3 gateway must be connected to the Internet.
If your devices are all Matter then you can use teh Matter controller of your choice. As it happens, the M3 is also Matter Controller. This means that it can also pair with non-Aqara Matter devices.
Now, as you are a beginner, I’m assuming you have no idea what Matter is. It is a Home Automation standard that enables sharing devices between different controllers (Such as Aqara, SmartThings, Apple Home, Google Home, Amazon Alexa, Home Assistant, etc)
The M3 can also act as a Matter Bridge, which means that if you connect an Aqara Zigbee device to it, and you decide you want to share it with another ecosystem, you can.
You don’t strictly need the M3 hub, but it helps with reliable automations. Aqara works best with its own devices; mixing brands or China/Global versions can be hit or miss. One hub might not cover a double-storey home fully. Gate automation is possible with a relay, but needs proper compatibility and setup.
