Node-Red & Hubitat Integration for Arlo Camera Lights
Hi everyone! I’ve been diving into the world of home automation lately, and I wanted to share my experience with integrating Node-Red and Hubitat to control my lights using Arlo camera motion detection. It’s been a bit of a learning curve, but I’m thrilled with the results!
The Goal
I wanted to automate my lights to turn on when the Arlo camera detects motion. Previously, I was using IFTTT for this, but the cost became prohibitive. So, I decided to explore Node-Red as a more cost-effective and customizable solution.
The Setup
  1. Node-Red Installation: I started by setting up Node-Red on my Raspberry Pi. It was surprisingly straightforward with the help of some online guides.
  2. Hubitat Integration: Next, I connected Node-Red to my Hubitat ecosystem. This allowed me to control my smart lights directly from Node-Red flows.
  3. Arlo Camera Integration: The tricky part was integrating the Arlo camera. After some research, I found that Arlo’s API could be used to detect motion events. I set up a webhook in Node-Red to trigger when motion is detected.
  4. Light Control: Once the motion event is detected, Node-Red sends a signal to Hubitat, which then turns on the specified lights.
The Challenges
  • Initial Setup: Getting Node-Red and Hubitat to communicate was a bit challenging, but with some trial and error, I figured it out.
  • Arlo API: The Arlo API documentation was a bit sparse, but I managed to find some community solutions that helped me set it up.
The Results
The system works beautifully! Whenever the Arlo camera detects motion, my lights turn on instantly. It’s been a great addition to my home security setup.
Tips for Others
  • Start Small: If you’re new to Node-Red, start with a simple project to get comfortable with the platform.
  • Community Resources: Don’t hesitate to look for help in forums or communities. There are tons of resources and people willing to assist.
  • Testing: Always test each part of your flow before putting it all together. This helps identify and fix issues early on.
Looking Ahead
I’m excited to explore more possibilities with Node-Red and Hubitat. Maybe next, I’ll look into automating my thermostat based on motion detection as well!
If anyone has questions or needs help setting up something similar, feel free to reach out. Happy automating! :rocket:
