OLED Display Issue with ESPHome
Hello ESPHome enthusiasts! I’m reaching out to seek some assistance with an issue I’m encountering with my OLED display setup. Let me start by providing some context about my project and the problem I’m facing.
Project Overview
I’m using an OLED daughter board connected to a D1 Mini development board for an infrared blaster application. The setup has been functioning smoothly until recently when I updated to a newer version of ESPHome. At this point, the OLED display stopped working, and I noticed excessive heat emanating from the display board. No changes were made to the YAML configuration file except for the ESPHome version update.
Configuration Details
Here’s a snippet of my ESPHome configuration related to the display:
display:
- platform: ssd1306_i2c
model: “SSD1306 64x48”
external_vcc: false
invert: false
rotation: 0
reset_pin: D4
address: 0x3C
update_interval: 120s
pages:
- id: page2
lambda: |-
if (id(hall_temp).has_state()) {
it.printf(0, 0, id(font4), “%.1f°”, id(hall_temp).state);
interval: 60s
Symptoms
  1. Display Failure: After the ESPHome update, the OLED display no longer shows any output. The infrared blaster functionality works fine when the display is disconnected, indicating that the issue is isolated to the display component.
  2. Excessive Heat: When the display is connected, it generates an unusual amount of heat, which is concerning and may indicate a hardware or software configuration problem.
Troubleshooting Steps
I’ve taken several steps to diagnose the issue:
  1. Checked Connections: Verified that all connections between the D1 Mini and the OLED daughter board are secure.
  2. Reviewed Configuration: Ensured that the YAML configuration hasn’t changed except for the ESPHome version update.
  3. Tested Without Display: Confirmed that the infrared blaster works as expected when the display is disconnected.
  4. Checked for Errors: Reviewed the ESPHome logs for any error messages related to the display, but found none.
Possible Causes
Based on the symptoms and troubleshooting steps, here are some potential causes:
  1. Software Incompatibility: The newer version of ESPHome might have introduced changes that affect the OLED display driver.
  2. Hardware Issue: The excessive heat could indicate a hardware problem, such as a short circuit or a faulty component on the OLED board.
  3. Configuration Error: Although the configuration hasn’t changed, there might be an oversight in the settings that became problematic with the updated ESPHome version.
Request for Assistance
I would greatly appreciate any insights or suggestions from the community. If anyone has encountered similar issues or has expertise in troubleshooting OLED displays with ESPHome, please share your experiences or potential solutions.
Conclusion
This issue is preventing me from fully utilizing my project, and I’m eager to resolve it. Your help would be invaluable in getting my OLED display back up and running smoothly!
Best regards,
