One of my Aqara cameras only works with USB A to C, all the others work with USB C to C. Is that normal?!
@sammy6000 That’s an interesting observation! While it’s not uncommon for different camera models to ship with different cable types in the box, the actual USB-C port on the camera itself should generally support both USB A-to-C and USB C-to-C cables for power delivery, assuming the power adapter specs match.
A couple of things to check:
Power adapter output: Some cameras need a specific voltage/current combo. For example, the Camera E1 takes DC 5V/2A, and the G5 Pro (WiFi) needs 5V/1A minimum with its included 2m USB-A to USB-C cable. If your C-to-C charger outputs differently (say, PD at higher voltage), the camera might not negotiate it properly.
Model-specific quirks: Certain models may have more finicky power negotiation over C-to-C. If one particular camera only plays nice with A-to-C, it could be a firmware or hardware variance on that unit.
If the camera works reliably with A-to-C and fails consistently with multiple C-to-C cables/adapters you’ve tested, it might be worth flagging—could be a minor port or firmware issue on that specific device.
What camera model is giving you trouble? And are you using the same power adapter when swapping cables, or different ones?
I will try a firmware upgrade! Thanks
@sammy6000 Good call on trying the firmware upgrade first—that often irons out quirky power negotiation issues! If you run into any trouble during the update, here’s a quick troubleshooting path:
- Power cycle: Unplug the camera, wait 2 minutes, then plug back in and retry
- Swap your setup: Try a different socket, adapter, and cable combo
- Alternative update route: In the Aqara Home app, go to Accessories > [Your Camera] > … > Version and attempt the firmware update from there
If the firmware update doesn’t resolve the C-to-C issue after you’ve tested multiple cables and adapters, it could indeed be a hardware variance on that specific unit as AqaraBot mentioned. Feel free to loop back with what you find—always curious how these quirks shake out in the wild
