Booth worked fine for 1,5 year. Just suddenly one of them disconnected.
Re-plugged, re-added several times, deleted from app, readded. Rebooted router, switched off 5GHz completely, used other USB cable, 2 other USB chargers. After re-adding 1 st seems okay, then no update on any movements, and app just tell “Network connection timeout suffered. Please check network connections” or similar. Then Blue-blinking light again, and greyed out from app. Sometimes comes back but still no function/connection.
Is there a hard-hard reset or emergency firmware update from PC wia USB cable?
If this unable to resolve, I won’t buy any Aqara device…have bunch of FP1E, those are unreliable as hell…E1 hub (bought just for these) literally 2 meters away, and have to re-plug weekly to work again.
I’ve also been using two FP2 presence sensors for 6 months, and I’ve encountered the same problem as you and tried similar methods as suggested. I still haven’t been able to resolve it. I constantly get networking errors and the FP2 sensors are rapidly blinking blue. I think with the latest update, the FP2 has become much more sensitive and fragile when it comes to WiFi.
Already ordered Everything Presence Pro…If those will be ok, then I step by step remove all Aqara FP2 devices.
Same here. I’ve already been in contact with Aqara Support about this. Did you also connect yours to the ‘soft sensor’ option right before it happened?
No I did not.
It’s absolutely wrong that we’re going through so much trouble and frustration for a sensor that promised so much. The money we paid for one could feed a child in Africa for 15 days. What you did is wrong; recall all FP2s and refund the money. Until this situation is resolved, I will not buy a single product from your brand. This is big wrong
Hi there, sorry for the inconvenience!
I’ve confirmed that our support team has been following up with you. Please feel free to reach out if you need any further assistance!
hi there, please check your email inbox. I’ve confirmed that our team has been following up but haven’t received a reply yet.
I swapped to Another FP2 (Which worked until now), and worked for a while on same location as the failing FP2 was used originally.
Then I tried to re-add, but i could not…
Then I went back to other sensor, same.
Then I disebled all my 5GHz networks, and succesfully added original sensor.
But I could not finish setup zones…(Hub or device not responding…), but i can see on screen myself moving…
I really tired from your stupid sensors…I give up, i want my money back.
I have plenty of smaret devices…soo many, and none of them is this bad.
One of my FP2s just disconnected from my network with no warning. I’m also unable to add it back, even after factory reset.
Is there anything useful Aqara can share with us about what to do when this happens? I often have the same problem with brand new FP2s, but eventually it works. This one though seems to be totally stuck.
