Hi everyone, I have six Aqara G5 Pro cameras powered using PoE splitters. Five have been reliable, but one repeatedly becomes unresponsive while its status light remains on.
It’s been a while since I last troubleshot this, so I can’t confidently list the checks I’ve already done. I’m happy to repeat tests to narrow it down.
Has anyone experienced something similar? I’d appreciate suggestions on how to narrow down whether the issue is with the splitter, Ethernet connection or camera itself.
What would you check first, and is there any diagnostic information in Aqara Home that would help identify the cause?
I’m having the same issue with one of my G5s. It repeatedly disconnects. I unplug it and plug it back in and it’s good for a few days but then the issue comes back. Would love to hear if/how you troubleshoot yours.
I have the same I recently installed 3 cameras but 1 every few hours becomes disconnected. The short term fix is to disconnect and reconnect the power. I would a proper solution.
Since five work and one doesn’t, I’d swap just one thing at a time: first the splitter with a working camera, then the switch port/cable if the fault stays in place. If the problem follows the camera, it’s the camera; if it stays, it’s power or cabling. It’s also worth checking the splitter’s power rating and whether the switch is near its PoE budget when all six are running.
I had a very useful email from the aqara technical support team after posting this but haven’t had time to actually troubleshoot. The interesting thing is the weather has changed in the past 2 weeks (in the UK) and is much colder than it was. The camera in question has been working fine since. It’s very odd - I think the likeliest scenario in my situation is a loose connection that is impacted by the warm weather. I don’t really want to tinker as its working fine for now but if it does start acting up I’ll follow the advice of the support team which is below:
To narrow down whether the problem lies with the splitter, Ethernet cable, or the camera itself, we recommend the following troubleshooting steps:
Inspect Cables and Connections: Check the Ethernet cable and PoE splitter connected to the affected camera for any damage or loose connections. Since your other five cameras are working well, try swapping the Ethernet cable or PoE splitter from a working camera to this one. This will help isolate if the splitter or cable is at fault.
Restart the Camera: Unplug the camera from the power source, wait about 10 seconds, and then plug it back in.
Check Network Stability: Ensure your network is stable. You may also try rebooting your router by unplugging it for about 30 seconds and then plugging it back in.
Verify Firmware: Please ensure that both the camera firmware and the Aqara Home App are updated to the latest versions.
Swap Test: Connect the problematic camera using a known-working setup (cable and splitter from one of the functioning cameras). If the camera works with these swapped components, the original splitter or cable is likely the cause. If it remains unresponsive, please let us know so we can assist you further.
If the camera remains unresponsive after trying the above steps, you may perform a hard reset:
Use the tool in the accessory pack to open the rear cover of the camera.
Long press the function button for 30 seconds.
After resetting, the status indicator should flash yellow, indicating it is ready for reconfiguration.
Please note that resetting will clear all data on the device, including schedules, battery records, and connected sub-devices. You will need to reconfigure and re-pair the device after the reset. Also, ensure the back cover is correctly reinstalled and the screw is tightened to maintain the IP65 waterproof seal.
That loose-connection theory fits well with the temperature angle: thermal expansion and contraction on a marginal RJ45 can absolutely cause this kind of on/off behavior as the weather changes.
One low-effort way to confirm it without tinkering: if your switch is managed, check the port statistics for that camera’s port. If the link drops and reconnects (link flaps) at the same times the camera goes unresponsive, it’s the cable/connector side. If the port stays up while the camera is dead, it’s the power side (splitter or the camera itself), which would also fit with the swap test from the support team’s list.
Since it works again now that it’s colder, I’d suspect a contact issue too. Outside, the RJ45 and the splitter connections move a little with the temperature, so a marginal one can drop and come back. The light stays on because the power is fine, it’s only the data that breaks.
If you have time, I’d redo the connector (an outdoor one with a boot is nice) and leave a small drip loop so water doesn’t run into the plug. If your switch is managed, the errors on that port can confirm it. Fwiw the PoE version of the G5 Pro avoids the splitter completely, one less connection to worry about.
