I installed the W200 not too long ago and the season has changed to start using the heat.
I’m only getting one fan speed though, low. Depending on the temp it reads it normally starts out low, but will kick to a higher speed when necessary.
It’s using 5 wires Y1, G, Rc, W1, C. These same connections on the Nest thermostat the W200 replaced, allowed the multi fan speeds to work.
What can be done to get this working properly?
I think it’s linked to your other post about the fan starting at the beginning of the heat. The W200 seems to energize G with the heat call, so the blower runs at the G speed (usually the low one) instead of letting the furnace choose its heating speed. The Nest had the option to let the furnace control the fan, the W200 doesn’t for now.
As a test, you can disconnect the G wire at the thermostat. The furnace will then control the blower by itself, but you lose the fan-only mode.
