Optimizing Automation Flows for Efficient Smart Home Management
I recently found myself in a situation where my smart home automation flows were being triggered more often than I’d like. After some research and experimentation, I discovered a method that might be helpful for others facing similar challenges.
When setting up automations, especially those triggered by motion sensors or door sensors, it’s crucial to consider how frequently these triggers are activated. I stumbled upon two approaches: using AND criteria within the flow itself or disabling the flow when it’s not needed.
Here’s what I learned:
  1. Using AND Criteria: This method involves setting up conditions within the flow to determine whether it should proceed. For example, if a motion sensor is activated, you can add an AND condition to check if the lock is locked before unlocking it. This ensures the flow only runs when both conditions are met.
  2. Disabling Flows: The alternative approach involves disabling the flow when it’s not needed. For instance, you could disable the motion-triggered unlock flow when the lock is already unlocked. This method can potentially reduce the number of active flows and might help conserve processing resources.
I experimented with both methods and found that disabling flows when they’re not needed could be beneficial, especially in setups with multiple triggers. It might reduce the overall number of active flows and, in some cases, improve performance by sparing the system from unnecessary computations.
However, I’m curious to hear other perspectives. Have others found a noticeable difference in performance by disabling flows versus using AND criteria? I’d love to hear any tips or experiences you’ve had with optimizing automation flows.
Let’s keep the discussion going and help each other create more efficient and reliable smart home setups! :rocket:
