Hey everyone! I wanted to share my journey with optimizing fan control using AppDaemon. I’ve been using a Tasmota device to manage my fan, which has a push button cycling through High, Medium, Low, and Off settings. Initially, I set up four separate scripts to handle each speed, but it quickly became cumbersome and inefficient.
After some research, I realized that using AppDaemon could streamline this process. I decided to consolidate my scripts into a single, more efficient solution. The key was to use an input_number variable to track the fan speed and conditionally execute actions based on the current state.
Here’s how I approached it:
Single Script for All Speeds: Instead of four separate scripts, I created one script that dynamically adjusts the fan speed. This reduces redundancy and makes future adjustments much easier.
Conditional Logic: I implemented conditional checks to determine if the fan is already at the desired speed. If it is, the script exits early, saving unnecessary iterations.
Efficient Cycling: The script cycles through the speeds by toggling the button and adjusting the
input_numbervariable. This ensures that the fan reaches the desired speed in the fewest steps possible. -
Error Handling: I added delays between actions to ensure the Tasmota device has enough time to process each command, preventing potential errors due to rapid successive commands.
The results have been fantastic! The script is now more efficient, easier to maintain, and has eliminated the clutter of multiple scripts. Plus, it’s fully integrated with Alexa, allowing me to control the fan hands-free.
I’d love to hear if anyone else has tackled similar challenges or has suggestions for further optimization! ![]()
