Optimizing Philips Hue Integration with Google Home
Hello everyone, I wanted to share my experience with integrating Philips Hue bulbs into both Samsung SmartThings and Google Home. While it’s great to have multiple platforms, I noticed a redundancy issue that might be helpful for others to understand and avoid.
So, I have Philips Hue bulbs connected to SmartThings, which allows me to automate them. I also connected my Google Home, which links to both SmartThings and Hue directly. The problem I encountered was that all my Hue bulbs appeared twice in Google Home—once from the Hue system and once through SmartThings. This duplication looked messy and could potentially cause conflicts when controlling the lights.
I started by questioning whether I should disconnect Hue from Google Home and solely rely on SmartThings for automation. However, I wanted to explore if there was a way to optimize this setup without losing the benefits of either platform.
I remembered using Trend Setter to create groups for my bulbs a year ago. At the time, Trend Setter didn’t support controlling both color and temperature in a single group, so I had to create separate groups for each function. Now, I’m wondering if importing these groups into Google Home would help streamline things or if it would just complicate matters further.
After some research and experimentation, I found that keeping the bulbs themselves in Google Home while avoiding the import of redundant groups was the key. This way, I maintain a clean interface and prevent conflicting commands. For example, if I ask Google Home to set the kitchen lights to red, it won’t mistakenly target both individual bulbs and the group.
I also discovered that using consistent naming conventions across both platforms helped reduce confusion. By ensuring that each bulb or group has a unique and descriptive name, I can easily identify and control them without overlap.
In conclusion, while having multiple integration points can be powerful, it’s essential to manage them carefully to avoid redundancy and potential conflicts. Taking the time to organize and streamline your setup can make your smart home experience much more enjoyable and efficient. I hope this helps someone else who might be facing similar challenges!
Best regards,
Simon
