Hi everyone, I wanted to share some of my recent experiences and tips regarding optimizing my smart home setup. As many of you know, maintaining a seamless and reliable system requires careful configuration and occasional troubleshooting.
1. Backup Configuration for DCE
I recently noticed that the backup retention policy in my DCE setup had changed. Previously, it only kept the last backup, but now I’m seeing multiple backups piling up. After some research, I found that adjusting the backup settings to limit the number of retained backups is crucial for maintaining disk space and system efficiency. If anyone is facing similar issues, I’d recommend exploring the backup settings menu to set a specific number of backups you want to keep.
2. InfluxDB Multi-Database Setup
Another area I’ve been working on is integrating multiple databases into InfluxDB for better data management. I have two databases: openhab_db and systems. Configuring both to work seamlessly with Grafana was a bit challenging at first, but I managed to get it sorted out. The key was ensuring that the correct credentials and database names were specified in the influxdb.cfg file. If you’re dealing with multiple data sources, make sure to test each connection individually before setting up Grafana dashboards.
3. Expanding Camera Systems
For those of you expanding your camera setups, I’ve heard a common question: Do I need additional modules if I have more than 10 cameras? From my research, it seems that most systems allow you to add more cameras without purchasing extra modules, but it’s always a good idea to check your specific hardware limitations. I’d love to hear from others who have successfully scaled their camera networks—what tips or tricks have you discovered?
I’d love to hear your thoughts or experiences with these topics. Whether you’re optimizing backups, managing multiple databases, or scaling your camera system, sharing insights can help us all improve our setups. Happy tinkering! ![]()
