Optimizing Smart Pump Automation with ESPHome
I’ve recently been diving into the world of ESPHome to create a smart pump automation system, and I wanted to share my journey and some tips I’ve picked up along the way. :star2:
My goal was to automate the operation of a pump based on specific time windows. I initially set it up to turn on between 10 AM and 6 PM using a simple lambda condition. It worked like a charm, but I quickly realized I wanted more flexibility. I wanted to set custom start and end times without hardcoding values, which led me to explore how to incorporate helper variables into my ESPHome configuration. :arrows_counterclockwise:
After some research and trial and error, I figured out how to use variables to store the start and end times. This not only made the configuration cleaner but also allowed for easier adjustments in the future. Here’s a snippet of what I ended up with:
yaml
if:
condition:
- lambda: ‘return id(ha_time).now().hour >= id(start_time) and id(ha_time).now().hour < id(end_time);’
then:
switch.turn_on: pump
else:
switch.turn_off: pump
This setup has been running smoothly for weeks now, and I couldn’t be happier with how it turned out! :muscle:
One thing I’d like to share is the importance of testing thoroughly. I spent a lot of time simulating different scenarios to ensure the pump would behave as expected. It might seem tedious, but it’s worth it to avoid any unexpected behavior once everything is up and running. :test_tube:
I’d love to hear from others who have tackled similar projects or have tips for improving automation setups. Drop your thoughts below—I’m all ears! :ear:
