I’ve been exploring ways to enhance the performance of my Remotec ZTS 110 thermostat, particularly in managing temperature swings. The default 0.5°C swing range has been causing some issues with my central water heating system, especially during rapid temperature changes. I decided to tackle this by creating a script to fine-tune the temperature adjustments.The goal was to reduce the swing range and make the heating system more responsive. I envisioned a system where the temperature would approach the set point more smoothly, avoiding overshooting. After some research, I developed a script that adjusts the heating based on predefined parameters. For instance, if the temperature is rising, the system heats until it’s just below the desired temperature, and if it’s cooling, it starts heating when it’s slightly above the set point.Testing the script has been enlightening. It significantly flattened the temperature swings, making the system more efficient. However, it required careful calibration to ensure it didn’t cause unexpected behavior. I also considered integrating this script with other smart home devices to create a more cohesive system.This experience has taught me the importance of understanding the underlying mechanics of smart devices and how custom scripts can enhance their functionality. It’s a rewarding process that combines problem-solving with the satisfaction of improving home automation. I look forward to sharing more insights and tips as I continue to refine my setup.
