Optimizing Z-Wave Switches with Door Sensors
Hi everyone,
I’m really excited about my recent smart home project, especially with Z-Wave devices. I’ve been working on setting up a scene where a Z-Wave wall switch controls a light, and a nearby door sensor triggers it. Here’s my setup: when the door sensor is tripped (not in armed mode), it turns on the light, and after two minutes, the light turns off automatically. It’s been working well, but I ran into an interesting challenge.
The issue arose when I manually turned on the light using the wall switch. If someone then triggered the door sensor, the light would turn off after two minutes, which wasn’t what I wanted. I wanted the light to stay on if I manually switched it on, regardless of the door sensor.
After some research, I discovered that using Lua scripting could help. I explored how to integrate Lua into my scene to check the state of the wall switch. If the switch was manually turned on, the scene should ignore the door sensor trigger. This way, the light would remain on as intended.
I also looked into using PLEG plugins for more advanced automation, but since I’m still learning, I focused on Lua for now. The process was a bit tricky, but I managed to write a script that checks the switch state and bypasses the door sensor action if needed.
This experience taught me the power of custom scripting in enhancing smart home automation. It’s amazing how you can tailor scenes to fit your specific needs. I encourage anyone facing similar challenges to dive into scripting—it might seem daunting at first, but the results are well worth the effort!
If anyone has tips or alternative solutions, I’d love to hear them. Happy automating!
Best,
