P100 Battery removal bricks sensor?
I got as P100 sensor. I had some trouble with it, but discovered a setup issue and took the battery out of the P100 so it would not drain. A couple days later I put the battery back in and it doesn’t work at all! Am I missing something. I hold down the button for 5 seconds, the light is not lighting up at all. What am I doing wrong, is this a design defect?
Hi @deviladv - did you also tried new batteries?
If it still not works, please contact the Aqara support
Hello @deviladv
The battery might have drained—try replacing it and checking.
Hello. Please double-check that there’s no plastic tape residue left on the contacts. I’ve already had this happen twice: when you pull the pull tab (battery/contact), a tiny piece of plastic gets left behind. Because of that, there’s poor contact. The first time it happened, I almost returned the sensor as defective.
