I have been trying in the last couple of days to do the updates of the P100, reaching timeout all the time. The download of the firmware is absolutely slow. I use the G410 as a hub, the chime is 50cm far from the P100 but I can’t make it happen. Any suggestions? Anybody had the same experience?
Stand next to the P100 and tap the button on top of the P100 to wake the device. You will see the blue light flash. Tap update the firmware while standing next to the P100 and after the Blue light is displayed.
It should update fine after that.
That’s what I did. Why my phone must be near the device?
I’m not exactly sure why taping the button and remaining next to the device speeds up the process?
I just recall reading it is recommended and also recall it working in the past plus it’s what I did this morning and it worked fine.
I tried multiple times in the same way…
- app always on on my iPhone
- Button pressed to wake up the device (done even regularly every 2/3 minutes)
- hub is 30 cm from the device itself
Start thinking something must be wrong other than the way the update is doing.
Hi, I removed the sensor and re-added it, and that worked for me. I don’t know if it was a coincidence or a pattern. Also, check the P100 battery charge level; that could be a factor too.
