One of my P100 multi-sensors is mounted on my freezer door; when the door is opened 90 degrees and then closed, it doesn’t register the closure. If the door is opened just 10 centimeters, it does register the closure. I have a second P100 mounted on the front door which works well even with the door fully open and then closed again
Thanks
Upright freezer or chest freezer?
The P100 reads the door angle magnetically, and the manual warns that motors and magnetic fields throw it off. A freezer has a compressor, and most have a magnetic door seal.
First, recalibrate: with the door fully closed and not moving, click the button 3 times. Aqara Team (ziqi_wei) said in #339245 that the lowest sensitivity setting tolerates more magnetic noise. If it’s a chest freezer, their other tip works too: the tilt trigger goes off gravity instead of magnetism.
