I just installed the w200 and now trying to add the p2 to home kit and it’s not working. It says unable to add accessorie pairing failed. Anyone know how to fix this issue.
Hi, which P2 sensor do you mean exactly?
Hello, I think the P2 motion sensor.
How many P2 sensor are there as I only know the thread version.now try to reset ether keep pressing the button till the LED start blinking or press 10 times in a row to factory reset it and set you phone on 2.4hz band or if you are using smart WiFi then keep trying a few time my be reboot the phone as with smart WiFi sometimes could give you this kind of error on the first try.i am telling this because I use smart WiFi and sometimes I do get that error but by trying a few times it works.
There are a P2 motion and a door / window sensor!
The W200 is a Thread boarder Router and should be able to link it to Apple…
Did you tried to add it direct to Apple? Or first to Aqara?
Do you use any other Apple related Matter hubs?
Got it I just sow the P2 crap with this P2 names ![]()
forgot about that window and door sensor that is P2 as well
