Good evening. I have a special problem with panel. I have there some lights but if i want turn on or off any lamp i need to click on display twice. first time i see animation of click but only on second time it is react and realy turn on or off light. This hapens when i go to panel. After twice click another laps work fine. Can you help me where is the problem?
Hello @pollak
What bulbs do you use? Maybe you have the opportunity to record a video and post it here, after that I am sure I can help you.
I am trying switch wall switch H1
I have the same issue with switches like a pulse contact through a Aqara dual relay.
The first hit makes the icon change as if it acknowledged the action, but nothings happens.
Only the second time you hit the icon the relay is actually responding.
I fixed it. You need to make a scene for light. example make scene living room with switch light in living room. and make scene on/off funkcion. It works perfectly now
OK, thanks for the information. But please tell us which bulbs causes the issue?
it was not issue with bulbs, but with switch. I dont have aqara bulbs.
