Pet Feeder C1 Guide
A new guide for everyone. As usual, the PDF is attached for you to download & feel free to pass it on if you think it can help someone.
Pet Feeder C1 Guide.pdf (250.3 KB)
Aqara Smart Home Info Sheet Series
Aqara Pet Feeder C1 – Smart Feeding, Automations & Zigbee Integration
Reliable feeding with Zigbee 3.0, local automation, and ecosystem control.
Overview
The Aqara Pet Feeder C1 is more than a basic automatic feeder β€” it is a Zigbee 3.0 smart device, capable of running local automations, acting as a Zigbee repeater, and integrating into complex multi-device routines in the Aqara ecosystem. It keeps stable connectivity to your Aqara Hub, supports remote control, and continues scheduled feeding even during internet or hub outages.
Although the Pet Feeder C1 is not natively HomeKit compatible, it can still be controlled through Apple Home using Aqara Hub automations. This makes it one of the easiest feeders to integrate into a smart home.
Usage & Reliability
  • Stable Zigbee 3.0 connectivity
  • Works as a Zigbee router
  • Supports schedules, manual feed, and remote feed
  • Feeding history with gram statistics
  • Optional LR20 battery backup
  • Local schedules continue even if internet or hub connection drops
  • 4L food tank suitable for cats and small/medium dogs
  • Built-in microphone for feeding voice prompts
Accessibility & Ease of Use
The C1 makes feeding simple and reliable β€” ideal for households with mobility challenges, busy routines, unpredictable schedules, or multi-pet setups.
Examples of helpful use cases:
  • Ensures feeding even if the owner is away or unable to bend/reach bowls
  • Voice announcements call your pet to the feeder
  • Scheduled feeding prevents accidental overfeeding
  • Remote feeding ensures pets are cared for when stuck at work or travelling
  • Local-run schedules protect against internet outages
Practical Scenarios
Scenario How It Helps / What It Does
Daily Feeding Routine Use scheduled feeding times, multiple portions per feed, and gram-based statistics for consistent daily nutrition.
When You Leave the House Automations can begin feeding only when no presence is detected, ideal for travel or unexpected absences.
If Your Pet Doesn’t Approach the Feeder Use motion sensors + automations to detect if food was eaten and skip or adjust the next feeding.
Monitoring Feeding Activity Pair with G3 / G2H Pro / G5 cameras to automatically record feeding events and verify your pet has eaten.
Improving Zigbee Coverage Place the feeder where Zigbee repeaters are needed β€” it strengthens and extends the network mesh.
Aqara Home Automations (WHEN β†’ IF β†’ THEN)
Example 1: Camera checks if your pet has eaten
WHEN: Accessories β†’ Pet Feeder C1 β†’ Food Dispensed
(Optional) IF: Time β†’ Daytime Only
THEN: Camera Hub G3 β†’ Turn to Feeder + Mark Event on Timeline
This records feeding moments automatically so you can confirm your pet ate.
Example 2: Pause next feeding if your pet didn’t come to eat
(Uses two automations because of IF conditions)
Automation A – Detect feeding event
WHEN: Pet Feeder C1 β†’ Food Dispensed
THEN: Start Timer for 3 hours
Automation B – Check motion before next feed
WHEN: Timer Ends
IF: No motion detected (Accessories β†’ Motion Sensor β†’ No Motion for 3 Hours)
THEN: Pet Feeder C1 β†’ Skip Next Feeding Portion
Useful for pets that graze slowly or medically monitored diets.
Example 3: Only feed automatically when nobody is home
WHEN: IF Presence Sensor β†’ No Presence for 24 hours
THEN: Pet Feeder C1 β†’ Feed Twice Daily
Helps when travelling or unexpectedly away.
Example 4: Use Pet Feeder C1 in Apple Home via Aqara Hub
While the feeder itself is not a HomeKit device, you can bridge it via an Aqara Hub.
Step 1 – Aqara Automation
WHEN: M1S/M2/M3 Hub Brightness = 1%
THEN: Pet Feeder C1 β†’ Dispense Food
Step 2 – HomeKit Automation
Use Apple Home to change the hub’s brightness to 1% (triggered by sensors, Siri, presence, time, etc.)
Result:
You can feed your pet entirely from HomeKit routines.
Apple Home Automations
Because the feeder itself doesn’t appear in Apple Home, you control it indirectly through the Hub Action (e.g., brightness at 1%).
Examples:
β€’ HomeKit Good Morning Scene β†’ Set Hub Brightness to 1% β†’ Feeder Dispenses
β€’ Motion Detected in Kitchen β†’ Set Hub Brightness to 1%
β€’ Leaving Home β†’ Automations feed pet automatically
This preserves the simplicity of Apple Home while still enabling smart feeding.
Tips for Best Use
β€’ Place feeder near a wall outlet or USB power
β€’ Use large dry food only (6–10g per portion depending on kibble size)
β€’ Set correct gram value per portion in settings
β€’ Replace desiccant regularly & keep feeder away from moisture and heavy foot traffic for fresh food
β€’ Use battery backup if feeding needs to continue during power outages
β€’ Pair with G3/G2H/G5 cameras for monitoring
Frequently Asked Questions
Q: What’s the maximum capacity?
A: 4 litres (approx. 1.7kg dry food)
Q: How many grams per portion?
A: Roughly 6–10 grams depending on kibble type.
Q: Can it charge batteries?
A: No β€” batteries provide backup only.
Q: Can it feed wet food?
A: No β€” dry food only.
Q: How long does battery mode last?
A: Around 45 days (feeding 5 servings once per day).
Q: Does it use battery power when plugged in?
A: No.
Final Thought
The Aqara Pet Feeder C1 is a surprisingly capable device - not just for feeding, but as a part of a larger smart home ecosystem. With Zigbee 3.0, local-run schedules, HomeKit-linked automations via the hub, and rich automation possibilities, it’s one of the smartest feeders currently available.
It keeps your pet fed, your ecosystem strengthened, and your routines effortless.
