Philips Motion Sensor Delay Issue Solved
Hi everyone, I wanted to share my experience with the Philips Motion Sensor and Homey Pro. Initially, I noticed a significant delay of about 3 seconds when using the motion sensor with Homey Pro, which was quite frustrating, especially in a dark hallway where instant lighting is essential. After some research and troubleshooting, I found that adjusting the flow settings in the Philips Hue app helped reduce the delay to almost negligible. Here’s how I did it:
  1. Checked Flow Settings: I revisited the flow configuration in the Philips Hue app and ensured that all settings were optimized for real-time response.
  2. Updated Firmware: Updating the firmware of both the motion sensor and the Hue Bridge also played a crucial role in improving responsiveness.
  3. Testing: Extensive testing revealed that the delay was primarily due to the initial setup and configuration rather than a hardware issue.
Now, the setup works seamlessly, providing the instant lighting I need. If anyone else is facing similar issues, I’d recommend checking your flow settings and ensuring all devices are up to date. Happy automating! :rocket:
