Presence detection with two FP300s in a room
After a brief experiment, I’ve gone all in on home automation, mainly using Aqara products. I have 17 FP300s around the house and I’m using it all through Zigbee2MQTT and Home Assistant. All the sensors are on firmware 6542. Generally it’s working well, but most of the problems I have seem to do with false or spurious readings from presence sensors and the most unreliable are in the two rooms where I have two sensors. In both cases the sensors are positioned on either side of a pillar, pointing away from each other. One room uses two sensors just because of the length of the room and they are treated as the same. If either of them shows presence then there is presence in the room. The other room has two seating areas and the lighting for each area is controlled by the sensor in that half.
Are there any guidelines as to how these should be configured or set up, for sensitivity, distance zones, spatial AI, etc. so as to avoid crosstalk between the presence radars of each sensor in the room.
If you use Zigbee mode, you are able to configure max range of the FP300. Open the device page, click three dots → On-Site Configuration → Detection Range.
The app will also show you how far is currently detected presence to help you set the distance properly. Setting this on both FP300s will help with separation of those two areas.
But unfortunately I can’t help with how to prevent interference. My FP300 regularly thinks there is someone when I open the window (I think the air from outside has dust and mmWave sensor just assumes it’s a person). Or when I turn on the oven, the heat triggers the PIR sensor. It needs about 20-30 minutes and then it corrects itself. I haven’t been able to fix this problem, I just live with it, because the sensor automates the LED strip, which is not too bright
There is nothing official besides not having the sensors face each other.
Will multiple FP2s in the same room interfere with each other?
Multiple FP2s in the same space generally won't interfere if not directly facing each other, allowing simultaneous operation in various modes.
That said, based on my own testing, I’ve had consistently worse results when using two mmWave sensors to cover the same room. I can’t say for certain that RF interference is the cause, but whatever the reason, I’ve found a single well-positioned sensor to be more reliable and predictable than trying to overlap coverage with two sensors.
So I’d definitely experiment with placement and orientation before assuming that adding a second sensor will improve coverage.
Thanks for this.
For one of the rooms (kitchen) I am experimenting with the “busy” end being PIR-only and the other end (with seating) using mmwave. That way the room should avoid radar conflicts.
The other room has two distinct seating areas with lighting, so needs two presence sensors with separate automations. Currently these two sensors are close together, but pointing away from each other, either side of a corner pillar. I’m am now worried about a radar “back-beam”. I wonder if things would improve if I move one sensor to another corner, still pointing away. The optimum positioning may take me some time.
Brian
Personally I would leave hybrid for the kitchen because despite it’s busy, it’s kind of a “work area”. You don’t want it to turn off your lights when you’re chopping a lot of veggies and it thinks there is no movement (because you’re standing in one place for a long time).
Another argument against using PIR only is that there is a lot of heat in the kitchen. You turn on the stove, you boil something, you turn on the oven. All those things generate heat, which, for the PIR sensor, means presence.
So if you leave the kitchen while leaving the soup/oven for a few hours, then it will still think there is someone (because PIR detects infrared radiation from all the heat). Or it will finally decide the heat is interference and it will ignore anyone coming to the kitchen.
It needs mmWave and AI learning to differentiate between a soup and a person.
I’d test the two sensors separately before changing too much. Leave them where they are, disable one for a day, then swap. If the false presence or clearing problems only show up when both FP300s are active, overlap starts to look more likely. If the problem stays with just one running, placement or field of view is probably the bigger issue.
For the lighting, I’d let either sensor mark the room occupied, but only turn the lights off after both sensors have been clear for a short grace period. That should reduce the on/off flicker and still leave useful logs to compare.
