Presence Touchscreen Switch S100 US (WS-K06D): no presence option anywhere
Product: Aqara Presence Touchscreen Switch S100 US, model WS-K06D, firmware 1.0.3.0 (hardware 1.0.0.0). This is the latest firmware offered; no update is available.
What I expected: The product name says “Presence.” The manual describes presence detection (3 m, 120°) and says that over Matter, Home Assistant, Apple Home, Google Home and Alexa get a “Presence/Occupancy Sensor.” It also describes a Presence Trigger setting under Settings > Presence Detection, and presence/absence as an automation trigger.
What I actually see:
  • The device is added to the Aqara Home app via Matter. The app shows no presence or occupancy option anywhere for this switch.
  • On the switch screen, the only related setting is Proximity Activation, which just wakes the screen. There is no Presence Detection or Presence Trigger menu.
  • In Home Assistant (also connected via Matter), the device exposes 42 entities. They are two lights (the relays), power, current and energy sensors, 8 button events, switch-position sensors, Thread and Wi-Fi diagnostics, identify buttons, power-on behavior selects and a firmware entity. There is no occupancy, presence or motion entity. The only binary sensor is “Hardware faults.” The full entity list is attached.
Questions:
  1. Does the S100 US have a working presence sensor, and is it enabled in firmware 1.0.3.0?
  2. If it isn’t enabled yet, what firmware will add it, and is there a timeline?
  3. Does presence require the device to be added through the Aqara Home ecosystem instead of Matter? If so, how, since I don’t see it?
  4. Will the Matter occupancy cluster be exposed so Home Assistant can use it?
Setup: Aqara M3 hub, Thread, Home Assistant (Matter), Aqara Home app.
@AqaraBot - please open a support ticket.
