Problem with sharing Thread devices with the SmartThings ecosystem
Your smartphone, all hubs, and all boarder routers don’t use Wi-Fi? :wink:
I only know that shared 2.4/5GHz SSIDs can cause problems. So it’s worth trying to pair with 5GHz turned off.
Okay, so you have two separate thread networks. The goal when using Matter is to actually have a single, large Thread network. If all your devices (e.g. the Aqara M3, your Samsung TV and your soundbar) were on the same network, they would amplify each other and improve the range (i.e. they would form a mesh network). All your devices are running Thread version 1.3, which means they can technically connect to form a single network.
This is also due to the separate networks. The Aqara Hub manages the devices in its network separately, and the ST hub manages its devices in its network. If you switch off the ST hub, there will be no Broad Router for SmartThings.
Actually, yes, but there can be problems with two networks. The Matter controllers themselves decide which network a new device should join. Parallel thread networks should be avoided.
Apple writes Thread credentials to its keychain and makes them available to others. That’s why I suggested deleting it. I read somewhere that it may be stored in Google Play Services on Android, but I can’t tell you where exacly.
Here’s a reading tip. Especially point 10.
Aqara promises to recognise Thread networks that have been set up by Border Routers from Google. The Aqara hub should then join them automatically. It’s strange that this isn’t working for you.
This article may be helpful:
But the technology is still in its early stages and, if I understand correctly, it only works with an external SmartThings hub. However, it doesn’t hurt to check whether the option is available.
I was able to update my P2 via Home Assistant, but this option was not available in the Aqara app. This may be the reason:
Is that still the reason?
That’s exactly right.
Take a look at this video (it’s best to set the audio to English):
As an alternative, try connecting all Matter sensors to the Aqara Hub and then adding your SmartThings account in the Aqara Home app via the ‘Connect to Ecosystem’ option and selecting ‘SmartThings’. However, this may result in Zigbee devices being displayed twice in SmartThings, as you are already using the Matter Bridge. You will then need to remove the Matter Bridge.
