Product requirements for outdoor lighting and yard ambience
These days, many people enjoy their own outdoor spaces—patios, gardens, balconies, backyards—or spend time camping and relaxing outdoors. Lighting plays a big role in these environments: it needs to be bright enough, create a comfortable atmosphere, withstand the elements, and ideally offer a smooth smart experience.
What do you usually do in your yard or garden? Have you set up any outdoor lighting of your own? Which products do you use the most? Have you run into any practical issues? And what kind of outdoor lighting do you feel you need the most? We’d love to hear your thoughts and experiences with outdoor lighting.
At this time of year, when the days are shorter and it gets dark earlier, security becomes especially important.
Currently, there is no wall-mounted outdoor light from Aqara for the EU market that provides both general illumination and security lighting. A photocell-controlled, PIR-activated lamp that switches on at full brightness when motion is detected, then dims down after a set time or following the last activation, would be a valuable addition to the Aqara ecosystem.
Ideally, the device should automatically switch off at dawn or integrate with Sunrise/Sunset automation logic. A device that is weather-resistant and made from high-quality materials that won’t yellow, fade, or deteriorate over time, even under harsh weather conditions.
I’d love to see some out door lighting. Below are a few items I’d live to see.
  • Something similar to the Govee permanent outdoor lighting.
  • Some RGBCCT ground lights to shine up to the house, in the back garden
  • I’ve like to see some outdoor lantern type lighting.
  • Wall lighting up/down RGBCCT
  • Obviously thread/zigbee switchable.
Kind regards
Dave
Good morning. Especially in moments of little heat, you can take advantage of the patio to relax or have dinner. The interesting thing would be non-direct lights to be able to generate atmosphere. In this way you can generate a warm lighting to relax but that also lets you see enough to be able to see. Depending on people’s needs, they might also need lights that illuminate a road.
Hi,
I’ve been a bit unfaithful and bought the Nanoleaf String Lights.
Surprisingly, they’ve worked flawlessly – honestly the only product from them that has ever done so.
But if I could change anything about the product, it would be the following:
  1. The brightness needs to be much stronger. With snow and darkness coming, you really need high lumen output.
  2. The bulbs should be smaller, ideally shaped like crystal or diamond. That would give them a more luxurious look.
  3. The bulbs should be connected directly to the main power cable, not hanging on separate little cords. (See image.) It would look much cleaner.
  4. Being able to choose how many bulbs light up would be amazing, and of course having several deep shades of warm white, yellow and red.
  5. They should also be controllable from your buttons, a easy way to dim them. that’s a dealbreaker. – that should probably go without saying.
  6. Add attachment points on the power cable so they can be hung on a steel wire or similar.
  7. The power cable doesn’t need to be black. A light gray or white cable would blend in with the surroundings far better.
Thank you for giving us the opportunity to share feedback – it’s genuinely appreciated.
I’m a big believer in “less is more.” I hate how so many recent smart string lights (like govee and nanoleaf) have highly stylised looks. I prefer something that blends in and looks like traditional lights. Similarly, when it comes to strip lights, I much prefer COB designs, where you can’t actually see the individual LEDs. And way too many outdoor strip lights are really thick and bulky - they should be flat and sit mostly flush against whatever surface they’re mounted (underside of eaves, railings, steps, etc). A solar option would be great for lights that are located further from the house. And now with the new FP300, it would be great to have an outdoor version with IP67+ rating, so it can better respond to lighting needs in real-time. I’m also a fan of portable tabletop lights (like the kind you get a restaurants) - it would be nice to have a smart, matter-enabled option like that as well. Finally, a solar-powered flood light for doorways/garages would be great. It should go without saying, but all of these should have tunable white light.
Hi, We are lucky enough to live in the San Francisco Bay Area where we enjoy relatively mild climate throughout the year. We do a fair share of gardening in the back yard but also enjoy the ability to open out backdoors and let a breeze come through the house. We eat some meals out back. I’ve set up some hue lights in back and have some Govee lights that I need to install too. Hue lights are great but I need to now install something over or replace the light switches.
Yes, we haven’t officially launched any outdoor lighting products yet. The scenario you described is very typical, and I’ve noted it down!
Cool, sounds like white light quality is really important to you.
I can totally picture it. The scene feels so vivid!
Wow, you even made an image for it. Thanks for the super detailed feedback, it’s really inspiring. You seem to care a lot about product details.
Got it! I’ll pass this on to our sensor product manager as well, haha
I for the past few years have gone the route of ‘dumb’ outside lights connected with Smart Plugs for my outside lights.
The lights I have are the Pro Connect range from Lights4fun which cone in a range of colours and you can buy in 5m strips and connect multiples to use just one plug all the way up to 200m, they are rated for outside use all year.
This means I can leave my lights out all year and set up Scenes and Automations to turn on the outdoor lights at Sunset and off at Midnight and have Scenes for Christmas, Halloween and all Year.
Using large electrics outdoor boxes and external power cable from the external plugs this all runs by itself and keeps nice and dry and away from the various garden pests :slightly_smiling_face:
As an added bonus I also have a number of Solar lights in the garden to compliment the plugged in lights.
If you wanted to also have security lights or just ones that turn on with presence you could go with one of Aqara’s battery Motion or Presence sensors, the P1 is under £20 and from the ones I have indoors the batteries last years.
For extended functions with battery power the new Aqara FP300 is an option.
Oh I’d also like to see an CCT / RGB / RGBCCT Led Driver, you used to have these for some other markets but I’d love to see an Aqara LED Driver.
