Products we want in Europe
and integration with European wall boxes
Haha… the same. :grin:
Such great ideas guys! :grin::ok_hand:
Everything on Chinese Aqara website should be available on europe, most important, the lights and led drivers :grin:
And double frames for H2 and other colours on separate parts to buy :muscle:
Maybe something new is coming soon:
Aqara Touchscreen Panel Switch S100 EU aufgetaucht – HomeKits.de
LED lamp e14
Battery camera who continue rec without WiFi or Internet or local network
A heat pump controller would actually be amazing! Ours is currently just connected to a Hive system and it’s a bit pants.
By the way,I have a question for you.Do you think that by 2025,the HDMI 2.1 interface will be a must-have option? thx!
Yes, same situation here (Czech Republic). Wish there would be more Aqara products available.
I want e-ink display 8-10 inch
I agree with the smart alarm (prefer zigbee over matter though) maybe if possible this is what you can do.
1x kit outdoor siren battery powered with simple underside security screw to remove to change battery (one is fine my current wifi alarm out door siren (yale has only 2 on front cover).
1x keypad with fingerprint reader for inside the home
option parts (obviously being with the aqara m.3 connection you could offer both options like the new sensor if it can work).
optional parts.
none of the motion sensors they detect cats if they jump over furniture.
in reality vibration sensors are to overated and can cause issues if large lorries drive past a building and will set off car alarm and your home alarm.
  1. motion sensor that wont be triggered by pets (has to be battery). (fp300)
  2. smoke alarm
  3. door and window sensor
  4. leak detectors
  5. panic buttom (aqara button on bed).
  6. gas detector
  7. tamper detection for out door siren and indoor siren.
  8. out building door sensor for sheds and offices, I do have one of your door and window sensors on my shed but feel for outdoors it needs to be a bit more robust.
  9. make sure the alarm trigger can be shared to other ssmart home items
  10. you could make up some kits witth this.
Some people could add to this I am sure
Personally the biggest want for me is a smart plug that support up to 3200 Watts (16 amp) as I run pretty big machines and arcade machines that draw that much power so at the moment I have to use another product for that which is really a shame.
A smart lock that is battery powered (for backup) and also DC/PoE powered via the latch.
:black_small_square: Blinds motor like the E1 but one that can handle cord not just chain
:black_small_square: Door lock for UK style UPVC five point lock doors
:black_small_square: Outdoor door sensors
:black_small_square: smart plant watering system (just to keep the mrs happy)
Outdoor weather station please!!
Also more kind of lights
Definitely an outdoor weather station
Using Aqara is always a good idea.
This is an amazing idea. A dedicated actual alarm system would really help set the smart home based on Aqara apart.
Carbon monoxide detector
  • A solar-powered WiFi outdoor surveillance camera with battery
