Protect Your Home with the Aqara Valve Controller T1 – A Smart Water Solution
I’m thrilled to introduce the Aqara Valve Controller T1, a groundbreaking smart water shutoff solution that offers peace of mind for every homeowner. This innovative device is designed to protect your home from water damage with ease and efficiency, making it a must-have addition to your smart home setup.
The Aqara Valve Controller T1 is a game-changer in smart home security. Unlike traditional inline valves that require professional installation, this device attaches externally to your existing shut-off valve, making it a DIY-friendly solution. Its compatibility with both lever arm and pinch grip valves ensures it can be used in various settings, whether you’re securing your main water line or protecting specific areas like your hot water tank.
Key features include:
  • Ease of Installation: No pipe cutting or professional help needed. Just mount and align for a seamless setup.
  • Manual Override: A physical button allows manual operation when needed.
  • Voice Control Integration: Operate the valve with voice commands via Alexa or other voice assistants.
  • Zigbee 3.0 Compatibility: Pair with Aqara hubs for seamless integration into your smart home ecosystem.
  • Automation Capabilities: Set up custom automations through the Aqara Home app, such as shutting off water upon detecting a leak.
This device is perfect for anyone looking to enhance their home’s security without breaking the bank. It’s a cost-effective solution that offers reliable protection against water damage, whether you’re home or away.
What are your thoughts on integrating the Aqara Valve Controller T1 into your smart home setup? Have you experienced any water-related issues that this device could have prevented? Share your experiences and questions below to join the conversation!
Is discount code still available?
Does this only work when connected to Aqara sensors?
I have an Aeotec Hub (Smartthings) and I was able to connect it with no issues. From what I read, however, is that you may need an Aqara Hub tonuse Aqara water sensors to operate it, TBC.
Does this controller also have HomeKit compatibility? do I need a hub?
Love mine, have been waiting for a battery powered option for a while!
I’m waiting for Aqara to release a water level sensor - I want to be notified when water in a tank gets to a specific level. Hmm, I wonder if a water leak sensor can be fully submerged - I may be able to use that if so.
You should be able to. A leak sensor is usually designed to be submerged in case of a big leak. You could use two, one for an shut off and one for an alert if it doesn’t shut off.
