Qubino Flush Dimmer Power Consumption Display Issue Solved
Hey everyone, I wanted to share a quick update about my recent experience with the Qubino Flush Dimmer (ZMNHDD1). I recently added this device to my smart home setup, and while it works perfectly for switching and dimming, I noticed that the power consumption wasn’t showing up. At first, I was a bit puzzled and concerned, but I decided to dig into the issue step by step.
I started by checking the device’s configuration in my hub. Everything seemed to be set up correctly, so I wondered if it was a firmware issue. I checked for any available updates and found that there was a newer firmware version available for the ZMNHDD1. After updating the firmware, I gave it a few minutes to reconnect and re-sync with my system.
To my delight, the power consumption started showing up clearly in my dashboard! It turns out that the older firmware didn’t support this feature as expected, and the update fixed the issue seamlessly. I was really impressed by how quickly the problem was resolved once I identified the right approach.
This experience taught me the importance of keeping devices updated, even if everything seems to be working on the surface. Sometimes, features that aren’t functioning correctly can be easily fixed with a simple firmware update. I’m now more confident in troubleshooting similar issues in the future.
If anyone else is experiencing issues with their Qubino devices, I highly recommend checking for firmware updates as a first step. It might just be the solution you’re looking for! Happy smart home tinkering everyone! :slight_smile:
