Can you recommend a way to support 433MHz? Do you know of any matter compatible 433MHz bridge?
@Pio_Wales I’m sorry, I couldn’t find any relevant information regarding supporting 433MHz or a Matter-compatible 433MHz bridge. Let’s collaborate in the community to see if others have insights or experiences to share on this topic. This way, we can all work together to find possible solutions. If you have any suggestions for improvement, you can submit manual customer service feedback.
I don’t think there is any sadly. But you can connect a classic Wi-Fi 433 MHz bridge and connect it to your Aqara or other ecosystem.
You mean you can connect it to hub m3? Does aqara supports 3rd party in that way?
I’m not sure about the M3 Hub, I know I have done this over Home Assistant, it makes everything interoperable.
I wanted to avoid adding HA. Having customized and tailored own server is thing of the future. I am looking to make it work as much as possible on the hub level. Thanks for your insight though :).
Sure, that’s understandable! When you do though, you’ll have trouble going back! ![]()
