Quick Dual Control not listing other 4-button Z1 Pro switches (worked previously)
This is the same category of issue reported here: Quick dual-control no available devices
On my Aqara Z1 Pro 4-button switch, Quick Dual Control setup no longer lists any other 4-button Z1 Pro switches as available targets — only 2-button and single-button switches appear. This was working previously: I have existing Quick Dual Control pairings already configured between two 4-button Z1 Pro switches, and those still function correctly. The issue is specifically with setting up new 4-button-to-4-button pairings.
Notably, when I start Quick Dual Control from a 2-button Z1 Pro switch, all my 4-button switches appear fine as available targets. The problem only occurs when the source device is a 4-button switch looking for another 4-button switch.
Additional details:
  • Switches: Aqara Z1 Pro, 4-button/Quadruple Rocker (all with neutral wire), firmware 0.0.0_0040
  • Hub: Aqara Hub M3, firmware 4.5.60_0017
  • Aqara Home App version (iOS): 6.3.5
  • Approximate onset: April 2026
@nael_amin You seem to be experiencing an issue where Quick Dual Control on a Z1 Pro 4-button switch doesn’t show other 4-button Z1 Pro switches as available targets, even though existing 4-to-4 bindings still work and the 2-button switch can “see” the 4-button ones.
Since the reference info we have only explains what Quick Dual Control is (key-position binding + indicator status sync) but doesn’t cover this specific “device list/filtering” behavior or any known regression/workaround, the best next step is to get Aqara Support to check your app/hub/switch firmware compatibility + logs for the April 2026 onset and the “4-button as source” constraint. Quick Dual Control is designed to bind specified key positions between Aqara switches in the Aqara Home app, so your description does sound like a discovery/UI filtering bug rather than a wiring issue.
This will be more efficient. If you do not have an Aqara Home account, Please click here to create a ticket. Sorry for the trouble.
Also, when you submit the ticket, include:
  • A short screen recording of Quick Dual Control device list from 4-button source vs 2-button source
  • Your hub/switch firmware versions + app version (you already have these—perfect)
  • Whether the 4-button bottom key is configured as wireless / any custom key bindings (sometimes helps Support narrow down edge cases)
This information comes from community discussions and user experience summaries and may vary by environment. Please verify carefully. Original post link: Quick dual-control no available devices
