Reducing Camera Reflections in Windows: A Simple Solution
Hey everyone, I wanted to share a quick tip that might help others dealing with camera reflections, especially those with cameras mounted near windows. I recently installed a new outdoor camera and noticed that during the day, the reflection from the lens was creating a glare on the window. It was pretty distracting and made the video feed less useful.
After doing a bit of research and experimenting, I found a simple solution. I decided to paint the front of the camera with a flat black poster paint. The results have been amazing! The glare is completely gone, and the camera is now much less noticeable from the outside. While it’s not as sleek looking as before, the practical benefits definitely outweigh the aesthetics.
Here’s what I did:
  1. I carefully painted only the front side of the camera that faces the window.
  2. I made sure not to get any paint in the microphone opening or on the light sensor.
  3. I let it dry completely before reinstalling it.
I also considered using a black marker, but I had paint on hand, so that’s what I used. If you’re worried about the appearance, a marker might be a better option since it’s less noticeable.
This fix has been a lifesaver for me, and I hope it helps someone else out there dealing with the same issue. Let me know if you’ve tried something similar or have other tips for reducing camera glare!
Cheers,
