I tried removing my FP2 to start fresh, but after deleting it, all the instances of it on Apple Home were still present.
I would have expected for them to be completely removed once the sensor was deleted from the Aqara app, isn’t it the case?
I needed to go into Apple Home and manually remove the sensor, which eventually did the trick.
Removing the FP2 from the Aqara app does not automatically remove it from Apple Home. You need to manually delete the device in the Home app. After removing it, power cycle the FP2 by unplugging it for a few seconds and plugging it back in. This ensures it’s fully unpaired and ready to be added again.
Thanks! Yes that’s what I ended up doing. I would have expected that it all would be gone as if it was on a bridge though ![]()
