Replacing a 2 Wire Garage Thermostat with W200 & Adapter
Hello,
Have a standard 2-wire 24VAC analogue thermostat in my garage connected to a gas heater.
No other wires are pre-ran and fishing would be a nightmare.
Does the Aqara C-Wire Adapter work like Nest’s where you simply wire in the adapter to the gas furnace and can then use the 2-wires already ran? If I have to run another wire I need to come up with another solution. And on that note, if this isn’t possible, can someone please link to a wall plug-in C-wire adapter in Canada that works with the W200?
Thanks!
@TheDaryShow Yep—W200 is a 24VAC-only thermostat hub, and it generally expects you to have a C terminal / C wire for power. If your existing setup is truly just 2 wires (typically R + W), you’ll need to add a C connection somehow—usually via a C-wire adapter rather than fishing a new wire.
Aqara’s guidance is basically: check whether your HVAC control board has a C terminal; if it doesn’t (or you don’t have a C wire at the thermostat), then you’ll need a C-wire adapter for the W200 to power up reliably.
On your specific questions:
  • “Does Aqara’s C-wire adapter work like Nest’s (installed at the furnace so you can keep the 2 wires)?”
    The reference info here confirms the need for a C-wire/C terminal and mentions using a C-wire adapter, but it doesn’t spell out the exact wiring behavior/details like Nest’s PEK for a 2-wire reuse scenario. So I can’t confidently say it works identically based on the info we have.
  • “Link to a wall plug-in C-wire adapter in Canada that works with W200?”
    There’s no reference info here confirming compatibility with any specific third-party plug-in adapter, so I don’t want to recommend a random one and risk instability/damage.
If you share a photo of your heater’s control board terminals (or list what terminals you have), folks can usually tell quickly whether you can use an adapter cleanly.
For the most accurate recommendation for your exact 2-wire garage heater setup (and Canada-available options), please reach out to support: Contact the Aqara Home App Customer Service Team (Profile> Help & Feedback > Customer Service) or scan the QR code:
This will be more efficient. If you do not have an Aqara Home account, Please click here to create a ticket. Sorry for the trouble.
Much appreciated!
My two options are going to be either to run a c wire or to pick up a 24VAC transformer that plugs into wall nearby. I will have to weight pros and cons of both. Thank you
@TheDaryShow That’s a sensible way to look at it. The big constraint with the Thermostat Hub W200 is that it’s 24VAC-only and it really expects a C terminal/C wire to power up reliably—so either adding a C wire or using a C-wire adapter is typically the path forward. This information comes from community discussions and user experience summaries and may vary by environment. Please verify carefully.
If fishing a new conductor is truly a nightmare, a local plug‑in 24VAC transformer can be a clean workaround in many installs—just make sure you stay within the W200’s supported input range (listed as 24V AC/DC, 18–30VAC). This information comes from community discussions and user experience summaries and may vary by environment. Please verify carefully.
If you want, drop a photo of your heater control terminals (or list what labels you have). Folks can usually confirm quickly whether you actually have a usable C at the heater and which option will be least painful.
