Review: ZemiSmart Smart Matter Hub M1 - A Comprehensive Look
The ZemiSmart Smart Matter Hub M1 has been a game-changer for my smart home setup. I recently had the opportunity to test this hub, and I must say, it exceeded my expectations in many ways. This review will walk you through my experience with the device, highlighting its features, performance, and overall value for users looking to integrate Matter and Thread into their ecosystems.### Packaging & ContentsThe packaging is sleek and minimalist, with the Matter logo prominently displayed. Inside the box, you’ll find the hub itself, a USB-C to USB-A cable, a user manual, and a SIM pin for resetting the hub. While there’s no power brick included, the USB-C port makes charging convenient.### Design & Build QualityThe hub’s design is understated, fitting seamlessly into any home environment. It features a Matter logo on top and subtle branding, keeping things simple and clean. The underside has rubber feet for stability, and the rear houses a USB-C port and an Ethernet jack. The design is minimalist, which I appreciate, as it won’t draw attention in my setup.### Features & FunctionalityThe M1 serves as a Zigbee hub, a Thread Border Router, and a Matter controller, making it a versatile addition to any smart home. It supports both Zigbee and Thread devices, allowing it to work with a wide range of smart home devices. The hub’s ability to act as a Matter controller is particularly noteworthy, enabling seamless integration with Matter-compatible devices.### Setup & ConfigurationSetting up the hub was straightforward. I used the Tuya app to add the hub to my network and then connected it to Apple Home via the Matter code. While the process initially seemed a bit confusing, the Tuya app provided a smooth experience once I got the hang of it. The ability to add Zigbee devices directly to Apple Home via the hub is a significant advantage, though some devices like buttons are still in the works.### PerformanceThe M1 has performed exceptionally well in my setup. It reliably connects and controls my Zigbee devices, including contact sensors, motion sensors, and temperature/humidity sensors. The integration with Apple Home is seamless, and I haven’t experienced any dropouts or connectivity issues. The hub’s signal strength is impressive, maintaining a stable connection even through walls.### ConclusionThe ZemiSmart Smart Matter Hub M1 is a solid choice for anyone looking to integrate Matter and Thread devices into their smart home. While it requires the Tuya app for initial setup, the ability to expose Zigbee devices to Apple Home is a major plus. The hub’s design, performance, and versatility make it a worthwhile investment for those aiming to future-proof their smart home setups.If you’re in the market for a hub that supports multiple protocols and offers reliable performance, I highly recommend giving the ZemiSmart Smart Matter Hub M1 a look. It’s a well-rounded device that should serve users well for years to come.
