I’ve been really happy with my Ring Pro doorbell, but I wanted to share some tips and experiences regarding sound quality and volume settings. After installing it professionally, I noticed that the mobile notifications were quite low, which was a bit frustrating. I spent a couple of hours on the support line, and while they managed to increase the volume slightly, it still wasn’t perfect. However, I’ve found a few workarounds that might help others facing similar issues.
First, ensure that your phone’s notification settings are optimized for Ring notifications. Sometimes, adjusting the notification volume separately can make a big difference. I also discovered that placing the doorbell slightly differently can improve sound projection. Experimenting with the angle and position helped me get better results.
Another tip is to check for any firmware updates for your Ring device. Updates often include improvements in audio performance. If you’re still having issues, consider reaching out to Ring support again—they were helpful once I escalated the issue.
Overall, while there were some initial hiccups, the Ring Pro has been a great addition to my home security setup. I hope these tips help others get the most out of their Ring doorbell experience!
