Hey everyone, I just wanted to share my experience with getting my Samsung NU8500 TV to work with Alexa again. It was working perfectly fine for a while, but suddenly, it just stopped responding to my voice commands. I could no longer turn it on or off, or even mute it through Alexa. I was really puzzled because I hadn’t made any changes to the setup. I use the Smart Things app paired with Alexa, so I knew the integration was there, but it just wasn’t working anymore.
I tried everything I could think of—restarting the TV, checking the Wi-Fi connection, ensuring the Smart Things app was up to date. Nothing worked. I even unpaired and re-paired the TV through the app, but it still didn’t solve the issue. I was starting to think I might need to contact Samsung support, but before I did that, I decided to give it one more shot.
I remembered reading somewhere that sometimes resetting the device can help. So, I decided to reset both my TV and my Alexa devices. I unplugged the TV for a few minutes to reset it, and I also restarted my Echo device. After that, I went through the pairing process again, making sure everything was correctly connected. To my delight, it worked! My TV is now responding to Alexa commands again, and I couldn’t be happier.
I guess sometimes a simple reset is all you need. I hope this helps anyone else who might be experiencing similar issues. It’s a relief to have my smart home setup working smoothly again. ![]()
