I recently encountered an issue while working with Home Assistant scripts that include delays. My setup involves looping scripts to fetch weather data, which helps optimize sensor updates based on current conditions. However, after reloading the scripts, I noticed unexpected errors, particularly when manually restarting the script. The errors seemed to stem from the script not recognizing its own state, which was puzzling.
After some experimentation, I realized that the issue might be related to how delays interact with script reloading. I decided to simplify my script structure and use external cron jobs to manage the timing instead of relying solely on Home Assistant’s delay function. This approach not only resolved the errors but also made the script more reliable.
For anyone dealing with similar issues, I recommend checking the script variables and ensuring that any external services are properly initialized before the script runs. Additionally, using cron jobs or other scheduling tools can provide a more stable environment for scripts that require precise timing.
Overall, while the initial problem was frustrating, it led me to a more robust solution. It’s a great reminder of how important it is to test scripts thoroughly and consider alternative approaches when encountering unexpected behavior. If anyone has tips or alternative solutions, I’d love to hear them!
