Hey aqara community.
I really like the aqara products, looking to improve the smart home, though I’m not as technical about it as I’d like.
I have the aqara G4 doorbell, which is great but recently the batteries get drained in a matter of days. I’m thinking of getting it hard wired in, but also considering the newer G410. Does anyone have any tips or experience with this.
Additionally I want an outdoor camera to capture the angles the doorbell doesn’t. So I’m interested to know what would be a good option here and systems for continuous recording and the set up here as I understand it will require an external memory storage set up.
Thanks in advance
Hi Ben! I use an Aqara doorbell with Apple Home and particularly like seeing the camera picture-in-picture on my Apple TV. I haven’t compared the G4 and G410 myself, so I can’t give you a reliable battery-life comparison.
Before replacing the G4, it may be worth checking how often motion events or live viewing are triggered and whether the connection is stable. If you consider wiring it, check the power requirements for your exact model and existing transformer first.
For the outdoor camera, I’d start by deciding whether you need continuous 24/7 recording or event clips, and whether local storage or Apple Home is most important to you; storage and recording options vary by camera and setup. Do you already have power or Ethernet available at the intended camera location? That could help narrow down the options.
Hi Ben, I’m in a similar spot – I’m planning my first Aqara setup and I’d like to add an outdoor camera on my balcony, so I’m following this thread with interest.
On the continuous recording part of your question: from what I’ve read, several Aqara camera hubs can record locally to a microSD card, and some models can also save to a NAS, but it seems to differ between models, so it’s worth checking the spec page of whichever camera you pick before buying.
@erhan82 – a question from my side, if you don’t mind: with your doorbell in Apple Home, do you keep the recordings in Apple Home (HomeKit Secure Video) or in the Aqara app? I’m trying to decide which ecosystem to rely on for clips.
I have a G400 that I hardwired to my transformer, my transformer is technically under the specs needed for the doorbell but it seems to work so far. I didn’t need a hub as I have an Apple TV 4K as the main hub and I use mostly HomeKit. Also didn’t want to bother with battery option as I had a battery ring doorbell and got tired of charging the battery every 2 months.
For external camera looking either getting the G5 pro or the upcoming G520.
I had the same issue with battery drain on the G4. I was planning on hardwiring it but eventually replaced it with the G400 and ran POE instead. It’s been rock solid since I made the switch.
