I’ve been trying to get my Everspring ST814 temperature and humidity sensors to work properly with my Vera system, but I’m running into some issues. Each sensor has a parent device and two child devices for temperature and humidity. When I check the advanced settings on the parent, the temperature and humidity readings match what’s displayed on the sensor itself. However, the child devices aren’t showing the same values, which is causing my Vera dashboard to display incorrect data. Sometimes the children update randomly, but it’s inconsistent and unreliable. I’ve tried recalibrating the sensors and resetting them, but the problem persists. Has anyone else encountered this issue or have any suggestions on how to fix it? I’d really appreciate any advice or insights!
