Seeking Help with RFXCom Device Disappearances After Reboot
Hey everyone, I’m reaching out to the community for some troubleshooting advice. I’ve been using RFXCom to control my KAKU/COCO plugs, and it’s been working great for the most part. However, I’ve encountered a puzzling issue that I can’t seem to resolve on my own.\Here’s what’s happening: I add a new device to my RFXCom integration, and it works perfectly. I can control it through Home Assistant and even include it in automations. But as soon as I reboot HA, the device disappears from the integration. When I check the diagnostics, it only shows 18 device_ids, even though I’ve added a 19th. I’ve tried generating a new ID and re-adding the device, but the same issue persists after a reboot.\I’m running HA OS 2022.7.3 on a Raspberry Pi 4 with 2GB of RAM. I recently upgraded from 2022.7.2, so I’m wondering if this issue is related to the update. I’ve also checked the logs, but I don’t see any obvious errors that point to the root cause.\Has anyone else experienced this issue? I’m curious if it’s a known problem with RFXCom or if there’s a workaround to ensure all devices remain recognized after a reboot. Any insights or suggestions would be greatly appreciated!\If needed, I can provide more details about my setup or logs. Thanks in advance for your help!
