Hi everyone, I recently switched from Wyze bulbs to Sengled Zigbee color bulbs after having trouble syncing them via HACS. I set up the ConBee II and added the Zigbee Home Automation add-on, and everything works perfectly with my wired lamps. However, I’ve encountered an issue with recessed ceiling bulb sockets controlled by light switches. After the initial setup, turning off the switch causes problems. Both HA and Alexa apps recognize the bulb but can’t control it. I can’t change the color, brightness, or turn it off/on. It still sees the bulb and sometimes determines the state, but infrequently. Additionally, if I change settings in the Alexa app, it reverts them after a few seconds. It seems like the Sengled bulbs can’t handle the power disconnect from the switch well. Has anyone else faced this issue? Is there a workaround? I’d appreciate any advice or insights!
