Sengled Contact Sensor Battery Issue Solved
Hi everyone, I had an issue with my Sengled contact sensors where after changing the batteries, the battery percentage wasn’t updating correctly. It was stuck on the old percentage, which was really frustrating. I tried refreshing the device and checking configurations, but nothing worked. After some research, I found that resetting the sensor by holding the button for 10 seconds and then re-pairing it solved the problem. Now, the battery percentage updates accurately again. I hope this helps someone else facing the same issue! :rocket:
